Home Forums Products Stompboxes Switch presets via MIDI ? Reply To: Switch presets via MIDI ?
#189177
joecozzi
    No. The H90 will only change Programs with program changes (PC) no matter what mode you’re in. You can also use a MIDI controller to increment, decrement, increment+load, decrement+load, bank up, bank down, active or bypass. In the System Menu > MIDI > MIDI-Global Control, you can assign CC# to each of these functions.
