Home › Forums › Products › Stompboxes › LFO reset (retrigger) in H90 when signal in the gate? › Reply To: LFO reset (retrigger) in H90 when signal in the gate?
Hi tbskoglund, many thanks for your reply! This is exactly the effect I am trying to achieve, I couldn’t have said it better! I would like to retrigger the LFO with a pick rather than the footswitch. Do you think it is feasible?
P.S.: I just realized I should have described the use case: it is about a band with just two guitars, bass and drums – no synths, no click tracks, no backing tracks, no midi clocks nor other midi equipment. And a real-life example is to play the single-note arpegiator intro of one of our songs using an electric bass (and a H90 running the hotsawz or polysynth algorithm, with the LFO synced using tap tempo). The intro is about 25 seconds long, therefore without retriggering it is essentially impossible not to have an audible drift (with the above mentioned setup assuming a small offset between the tapped tempo and the actual one, as played by the drummer). In case it helps, here is the link for the track -> https://haneketwins.bandcamp.com/track/feel-the-burn
