Home › Forums › Products › Stompboxes › LFO reset (retrigger) in H90 when signal in the gate? › Reply To: LFO reset (retrigger) in H90 when signal in the gate?
Hi tbskoglund,
Many thanks for your reply! This is exactly the effect I am trying to achieve, I couldn’t have said it better! I simply prefer to retrigger the LFO using a pick rather than a footswitch, that’s all. Do you think such a feature could be feasible in an upcoming firmware release?
P.S.: I should have mentioned that we are a band with only two guitars, bass and drums. On stage, we do not use synths, click tracks, backing tracks, midi clocks nor other midi equipment. An example case is to play the arpeggiator part in the intro of one of our songs using an electric bass and the H90 (with the HotSawz or Polysynth algorithms). Since the part is pretty long (about 25 seconds), and the tempo tapped in the H90 doesnt match perfectly the actual tempo as played by our drummer, we often have audible drifts, thus the need for a convenient way to retrigger.
P.S.2: for some reason, my initial reply did not go through thus the repost – apologies for the duplication
