Home › Forums › Products › Stompboxes › LFO reset (retrigger) in H90 when signal in the gate? › Reply To: LFO reset (retrigger) in H90 when signal in the gate?
#189200
    Hey, pvichoudis.  Sometimes a link or attachment flags a post for moderation.  It’s happened to me.  Seems like the forum security has ramped up lately, along with the bot replies with buried links in them.
    I didn’t mean to get all technical.  Just thinking through the process, hoping to land on a simpler workaround.  Eventide developed a killer envelope follower, which is the first part needed for your feature request.  Matching it with the gate hold length would be the next step.
    The Envelope Follower would also need to be linked to Retrigger, and probably done globally (available to any Program).  I can’t seem to think of an easier way to get you there now, with your current band setup.  MIDI does make it easier for sync’ed effects like this.  I also understand that live, no one wants to be strictly locked to dehumanized timing.
    Stuff like ‘Boulevard’ … I had that effect set up in an AdrenaLinn III.  We pretty much had to play to that effect, not the effect following us.  And I suspect Green Day might’ve done the same.
    Just some thoughts that haven’t gotten you any closer.  As it stands now, the options for Retrigger alone consists of external or onboard switching, or MIDI CC control.
