Home › Forums › Products › Stompboxes › Instrument and line level settings for insert effects › Reply To: Instrument and line level settings for insert effects
Thanks
i understand the theory regarding signal levels. It’s more about clarifying what the H90 is actually doing when an instrument level insert is used.
So you mean if I am sending a line level signal into inputs 1 and 2 (which are set to line level) and I then send that signal into my stereo insert (which is set to instrument level) the H90 is automatically reducing the signal level hitting the insert for me without me needing to adjust anything?
And when I send the output of that insert back into the H90 it will also automatically increase the signal level again to match the line levels of output 1 and 2 (if they are set to line level)?
