Home Forums Products Stompboxes H9 MIDI Bypass CC message Reply To: H9 MIDI Bypass CC message
#189311
    Which pedal function on the H9 do you have your CC 0 mapped to? You should be using the “Toggle between Active and Bypass” pedal function.
    I’d suggest using H9 Control to make your MIDI mappings since it is easier to confirm you have the right functions mapped.
