Home Forums Products Stompboxes H90 – Overdrives in loop question Reply To: H90 – Overdrives in loop question
#189339
    Ok, thanks for the information.
    What happens if you remove the PC message? Are you then able to get the toggle to work?
    The latest firmware for the H90 has some issues where a PC+CC message may not work properly. If you email support@eventideaudio.com I can help you install a previous version of H90 software that may resolve the issue.
    But just for some additional information, what are you trying to accomplish with the setup here?
    If you send a PC+CC to load and activate a program, you will be in toggle state 2 which will then allow you to bypass the program, correct? But then if you want to activate the program again, you will first be reloading and then activating it again (because you are sending the PC+CC message for the first toggle state).
    You can configure all of your H90 programs to load in the correct active/bypasses states, but I understand that some users want to control the active/bypass states with a CC message, so I’m just trying to get a better idea of your setup.
