Home › Forums › Products › Stompboxes › Using RJM PBC/6x with H90 for Looping › Reply To: Using RJM PBC/6x with H90 for Looping
April 4, 2025 at 6:15 pm
#189441
Hello mnkyby66,
To get the H90 to toggle into Perform Mode you can assign a CC# to the Perform mode parameter in System Menu > MIDI > Global-MIDI Ctrl > Parameter > PERFORM Mode. When you assign a button on your MIDI controller to send that CC# with value 127, the H90 will switch to PERFORM mode. Consecutive presses will take you through the PERFORM mode pages. It is possible to save your Looper Program to already be on the Looper Control perform page, so that when you switch into PERFORM mode the first time, it will go straight to the third page.
