Home Forums Products Stompboxes Eventide H90 MIDI PC Change and Bypass at the same time Reply To: Eventide H90 MIDI PC Change and Bypass at the same time
#189561
stroboscapes
    Then it doesn’t work with the firmware version 1.8.6. that allows additional values to be recognised by the device after a PC change.
    I tried sending 127 to “P Act/Byp” and it will change the state from say bypassed to active. Sending 127 on the same CC again bypasses it from active. I would expect by the manual that 0 would be bypass and 127 active, but 127 just toggles it. So there is no way to definitely send a value for Bypass.
    Using “P Act/Byp (M)” does the same but only activates it for a brief moment.
