Home › Forums › Products › Stompboxes › Eventide H90 MIDI PC Change and Bypass at the same time › Reply To: Eventide H90 MIDI PC Change and Bypass at the same time
April 14, 2025 at 11:30 am
#189565
I’m sorry, I don’t have any further information to provide.
As described above, you need to use P Act/Byp (M) and you need your MIDI controller to only send the specific high or low CC value, then it should work correctly for discrete active/bypass messages when using P Act/Byp (M). Many users use the H90 with MIDI this way.
