Home › Forums › Products › Stompboxes › Syncing DA micro.CLOCK gen3 Timefactor › Reply To: Syncing DA micro.CLOCK gen3 Timefactor
April 15, 2025 at 9:20 am
#189573
You will need to configure the aux switch input to be mapped to tap tempo, see page 47 of the user manual here: https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/TimeFactorManual.pdf
You should also turn Tempo Mode on, see page 39. Once you have this setup correctly, you should see the pedal UI update when you get tap tempo messages from the micro clock.
