Home Forums Products Stompboxes Syncing DA micro.CLOCK gen3 Timefactor Reply To: Syncing DA micro.CLOCK gen3 Timefactor
#189588
DrewPac5877
    Update. Spent about an hour with my TimeFactor and micro.Clock this morning. I feel like the adjustments I’m making aren’t doing anything. I go Auxiliary Switch and select TAP < T+R and all I get wheen I push the micro.Clock is the Bypass Active which is the first selection in the menu. Go back to Tap < T+R and try to configure different options. Same problem. Pressing the middle foot switch once selected to bring me back to the main menu.
    At this point I don’t know if the problem is with the clock or the the TImefactor. I just want to eliminate one of the two so I can focus on just one.
