Home › Forums › Products › Stompboxes › Syncing DA micro.CLOCK gen3 Timefactor › Reply To: Syncing DA micro.CLOCK gen3 Timefactor
#189609
    Sorry to hear you are still having issues.
    I would suggest unmapping the default mappings first. It sounds like your micro.Clock is triggering the bypass, when you only want it to trigger the tap tempo.
    From the aux menu, the first option should show “BYP < TIP”.  Press the right footswitch so it now shows “BYP > TIP”. Turn the encoder left, to unmap the Tip from the Bypass command. Then press the encoder again.
    Once you have unmapped all the aux switch mappings, select Tap. Press the right footswitch untill you see LEARN. Once that is displayed, press the footswitch on the micro.Clock and the Time Factor will learn this command for tap tempo.
    That is everything you need to do to map tap tempo to the aux switch. Let me know how it goes.
