Home › Forums › Products › Stompboxes › H90 Feature request: More more effects at once in the chain › Reply To: H90 Feature request: More more effects at once in the chain
April 29, 2025 at 4:43 am
#189828
It would be amazing to have an EQ (variable LP/HP) and a compressor as two inserts before the algos are hit. This would help so much! Another EQ after the algos would be another great plus. The EQ/Comp also is pretty much useless because it doesn’t have a lpf or hpf and a hpf is exactly what I would need. Best scenario: Input > EQ with HPF > Comp > Algos or H90 as is right now > output. Thank you!
