Home › Forums › Products › Stompboxes › Tricerachorus Pedal Issues / Suggestions › Reply To: Tricerachorus Pedal Issues / Suggestions
May 1, 2025 at 5:26 pm
#189956
Thanks for your post. Sorry, but the dot9 pedals are not a platform where there are feature changes and updates, they are “feature complete” and the parameters have been set from the product designer.
For numbers 1 and 3, I think using a MIDI controller would be a good solution. If you have a flexible MIDI controller, you can reorder the parameter however you like. You could also potentially reverse the direction of the filter knob depending on which controller you are using.
You could also use a computer or iPad with H90 Control to adjust the parameters.
