Home › Forums › Products › Stompboxes › H90 Pitch Flex bug › Reply To: H90 Pitch Flex bug
I spent some time with PitchFlex using H90 Control (not using the pedal as the interface like the OP) today.
I can reproduce the behavior described in the OP’s post dated April 24.
More generally, I tested various other things as well. I believe there is a problem and that it is limited to the Manual Shift parameter as reported. The visual position of that parameter control saves properly (where ever I set it). However, the underlying value of that parameter is never saved. Instead, (as reported) the underlying value of that parameter is always -1 upon recall of a saved preset (you can clearly hear it). To keep things as simple as possible I tested out various factory presets and only made this one change before saving. Same problem every time.
I continued on to test various other parameters using various factory presets and did NOT have a similar problem with any of those other parameters.
Thus, the error appears to be limited to the Manual Shift parameter.
I hope that helps.
