Home Forums Products Stompboxes H90 Pitch Flex bug Reply To: H90 Pitch Flex bug
#190091
joecozzi
    The Manual Shift parameter is meant to be a realtime control, so it will only sweep the pitch when the H90 senses it’s being moved. It should not be used to achieve a starting pitch. As it pertains to GEDDN’s post, if you wish to achieve the +2 Octave pitch upon loading the Program, it’s better to set the Heel A parameter to +2 Oct and the Heel B parameter to +1 oct while maintaining Manual Shift at it’s default value of zero. The Toe parameters should be set lower than +2 Octave if you need to access lower pitches upon moving the Manual Shift.
