Home › Forums › Products › Stompboxes › Routing/switching H90 outputs › Reply To: Routing/switching H90 outputs
May 12, 2025 at 1:41 pm
#190122
Thanks for your post. Answers below:
Example 1:
– Outputs 1-2 are a stereo pair, you should not use 1 for the dry output and 2 for the wet output.
– Wet/Dry setup instructions can be found here: https://cdn.eventideaudio.com/manuals/h90/1.10.7/content/setup/wet-dry.html
– If you need another output signal, you can enable insert 2 for the combined mono output.
Example 2:
– Place a stereo insert at the end of your signal path, and set the insert mix to 50%. This will give a duplicate copy of the signal on outputs 3-4
