Home Forums Products Stompboxes Routing/switching H90 outputs Reply To: Routing/switching H90 outputs
#190123
tirwin
    Thank you for the quick response.
    I am probably using outputs 1&3. It’s been a while since I looked at the cabling. (not at home to look so I assumed… )
    To confirm my understanding:
    With the amps, if I want to say run weedwhacker and send it to the dry amp and reverb to the wet amp, I would use parallel routing and put insert 1 after the weedwhacker on Preset A with the Insert mix set to 100%. Kill dry set on output 3 to wet amp.
    If I wanted to run say delay and reverb, I would run them in series on Preset B to only go to the wet amp.
    Then, when I add the sim pedal, I add insert 2 at the end and use output 2 for combined mono output.
    Did I get it right?
