Home › Forums › Products › Stompboxes › H90 User List Organization › Reply To: H90 User List Organization
The H90 has a fixed amount of Programs (99 per list) and this cannot be changed. We do not currently have plans to change this since it would require very significant changes to how the pedal works.
How are you selecting your presets on the other pedals?
Using Select Mode on the H90 makes it pretty easy to figure out which Program is loaded and which Program you may load next without spinning off into the danger zone. You may also have the additional program slots filled with “INIT program” so if something is loaded by accident it there will be no effects processing rather than the wrong effects processing.
MIDI Program Changes would be a very efficient way to manage all of your devices and is how many engineers and users would accomplish this task. For example, you can send a PC for any of your songs in the setlist to easily change the programs/presets on all the devices instead of individually managing each device. It just takes some time and effort to set this up properly.
Sorry if this is an inconvenience but my best suggestion would be to figure out how to manage the list of 99 Programs in a way that can work for your setup.
