Home › Forums › Products › Stompboxes › Anyone able to replicate the Hazarai MBV sound on Timefactor? › Reply To: Anyone able to replicate the Hazarai MBV sound on Timefactor?
May 20, 2025 at 2:13 pm
#190235
Well, I’m not too happy with matching up the TF Depth / Taper to the EHX Decay / Rise. Sounds like the tap buildup is over an exponential curve. I compensated somewhat, adding extra Wet Mix. Feedback A (optional) is just there to double up on Dly B.
You’ll be able to tweak it closer with a side-by-side comparison. A touch of Xnob / Slur does add a little separation from your dry input, but any amount is going to blur out the attacks, to some extent. Of course, Dly B can range up to 1050 mS, but I’d keep Dly A around half of that, to increase the apparent taps.
