Home › Forums › Products › Stompboxes › H90 Routing with Friedman IR-x › Reply To: H90 Routing with Friedman IR-x
May 28, 2025 at 9:37 am
#190360
You’re welcome.
I don’t think that will change how your setup sounds. This is just a different way of accomplishing the same thing. Both of these options give you the same results; you can choose where the IR-X is and where both of the H90 presets are in the signal path.
The routing demonstrated in the video is very simple: Guitar > IR-X > H90. Have you tried this?
There may be some other factors for why your setup does not sound the same as the video (different guitar, pickups, playing style, post processing, etc.)
