Home Forums Products Stompboxes H90 after amp modeler/profiler Reply To: H90 after amp modeler/profiler
#190379
apalazzolo
    hi,
    you have a lot of configuration options and i’m sure you’ll soon get great advice on that from the experts here (so i’ll leave that to them).
    i came to say that i’ve been using quality headphones plugged into the stereo outputs of the H90 for two years and it has always worked great.  i use a basic Y-adapter and my headphones are considered low impedance (24 ohms).  i’m using denon ah-5200 but i expect any quality headphones will be fine. but i also suspect that headphone use is not recommended by Eventide.  so there’s that.
    i boost the output of the H90 to +12 dB to drive the headphones and that parameter is called “P out”.   it’s just the right volume for me and it is crystal clear.
    good luck!
