Home › Forums › Products › Stompboxes › H90 Output 3/4 Issues with Xone96 › Reply To: H90 Output 3/4 Issues with Xone96
May 29, 2025 at 9:50 am
#190388
Let’s try a few things,
- Can you send me a picture of your Routing mode? I want to double check you’re on Dual Routing mode.
- Put THRU utility algorithms on both Path 1 and Path 2 just to test you’re passing audio through. I recommend using an INIT Program on User 2 list. That’s the most basic starting point of a program on the H90.
- Make absolutely certain that
SND L on the XONE is going to IN 3 on the H90.
SND R on the XONE is going to IN 4.
Out 3 on H90 is going to RTN L on XONE.
Out 4 on H90 is going to RTN R on XONE.
It’s not uncommon to make the wrong connections. If that does not solve the problem… - Disconnect Path 1 (I/O 1/2) from Send A on the mixer and use the same cables to hook up Path 2 (I/O 3&4) to Send A. Do you still encounter a problem? If not, try the other set of cables again. Perhaps you have a messed up cable?
Let’s start there.
