Home › Forums › Products › Plug-Ins › Octavox Delay Time Constrained, and MIDI not working? › Reply To: Octavox Delay Time Constrained, and MIDI not working?
Glad to hear you are enjoying the plug-in. Answers below:
1. The max delay time for any voice or the total loop delay is 2.4 seconds.
1a. Under the “Scale” dropdown menu there is a “Sync” dropdown menu. If you select “Session” the plug-in will sync to your DAW’s tempo.
1b. In the musical notation section of the UI, you can drag the notes for tempo based divisions. For example, at 120 BPM drag one of the notes right by 1 quarter note on the notation UI, and you can see that the delay time will be set to 500 ms.
1c. Correct, the total delay time cannot go above 2.4 seconds. The notation UI reflects this and will scale down when using slower BPMs.
2. For MIDI control using Logic, you need to create a new instrument track, and select the plugin as the instrument (it will be listed under AU MIDI-Controlled Effects->Eventide->Plugin Name). Then, select the track with the audio you want to process in the Sidechain menu in the top right of the plug-in window. Now, if you have the instrument track selected, you should be able to play/record MIDI notes affecting the source audio.
Let me know if that helps.
