Home › Forums › Products › Stompboxes › H90 Dual Stereo Options › Reply To: H90 Dual Stereo Options
June 3, 2025 at 10:32 am
#190466
To do this, you would have to switch the H90 to Insert Routing mode. The advantage is you get two insert loops you can place anywhere in the chain. I don’t recommend this for because you’re running stereo wet effects and the independent inserts on the H90 run in mono. There is a stereo insert but it combines I/O 3&4 causing you to lose one insert point.
