Home › Forums › Products › Stompboxes › H90 Preset value doesn’t load after expression pedal change › Reply To: H90 Preset value doesn’t load after expression pedal change
June 5, 2025 at 12:15 am
#190485
Parameter value is supposed to go back to the stored value once you switch back to the original Program. The only way it doesn’t is if it senses movement on the EXP input. What algorithm are you using? How do you have it mapped, parameter directly to the expression or parameter to a hotknob that is mapped to an expression?
