Home › Forums › Products › Stompboxes › H90: recreating slow/fast switch in midi › Reply To: H90: recreating slow/fast switch in midi
[Edit: Too slow for Joe]
… I am asking what h90 setting I’m even supposed to be fiddling with.
If I am understanding correctly, you would need to use Global Mapping to emulate how the H9 addresses the [PSW] mappings.
The H9 had to combine the ‘3rd switch’ functions of the TimeFactor, ModFactor & PitchFactor with the unique-to-Space hotswitch function, all while accommodating both types of controls in the newer H9 Special algorithms.
It’s more versatile in the H90, splitting up the functionality. You can map to each Performance switch individually. The 3 HotSwitches can each cover any combination of base parameters in any of the algorithms now. And each of those momentary or latched HotSwitches can also be mapped to a controller individually.
HotSwitches are saved at the Program level, and Performance switches at the Preset level. You can either map each type consistently to a particular slot in every Program / Preset, or map that slot to a control globally across any Program / Preset.
