Home Forums Products Stompboxes Question About Output Routing: OUT1 (Dry+Wet), OUT2 (Wet Only to Amp2) Reply To: Question About Output Routing: OUT1 (Dry+Wet), OUT2 (Wet Only to Amp2)
#190666
thejohnsupremo
    There are a lot of unanswered questions about the routing ability of this device. It seams very overlooked by Eventide who could show all of us musicians who are not tech savvy a handful of possibilities. Currently I think they show just a few uses in the manual but I mean there are a lot of options I THINK. Can some of the inputs and outputs be used to run other pedals through just in a bypass mode so you can take advantage of your amplifiers single effects loop without placing those pedals before or after effects being used in the H90?
