Home › Forums › Products › Stompboxes › Question About Output Routing: OUT1 (Dry+Wet), OUT2 (Wet Only to Amp2) › Reply To: Question About Output Routing: OUT1 (Dry+Wet), OUT2 (Wet Only to Amp2)
June 20, 2025 at 10:46 am
#190671
Outputs 1-2 will always be a stereo pair. You can follow the instructions from the manual for a wet/dry setup: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/setup/wet-dry.html
In that example, output 3 will be the dry signal and output 1 will be the wet signal.
