Home › Forums › Products › Stompboxes › Question About Output Routing: OUT1 (Dry+Wet), OUT2 (Wet Only to Amp2) › Reply To: Question About Output Routing: OUT1 (Dry+Wet), OUT2 (Wet Only to Amp2)
June 20, 2025 at 10:48 am
#190672
Hi thejohnsupremo I’m not fully understanding what your question is.
You may use other guitar pedals in the insert path of the H90, instructions for that are here: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/setup/two-mono-inserts.html
You can have the inserts active when the H90 is bypassed by setting the Bypass mode to AB only: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/system-menu/global.html
