Home › Forums › Products › Stompboxes › Question About Output Routing: OUT1 (Dry+Wet), OUT2 (Wet Only to Amp2) › Reply To: Question About Output Routing: OUT1 (Dry+Wet), OUT2 (Wet Only to Amp2)
Thank you for the clarification.
I understand that outputs 1-2 are always treated as a stereo pair, and I appreciate the information about the wet/dry setup using Output 3 for dry and Output 1 for wet.
However, I personally would love to be able to route Dry + Wet to Output 1 and Wet-only to Output 2, so I can send a full mix to Amp1 and only the wet signal to Amp2.
I’m not sure if other users are looking for the same routing option, but I believe it could be very useful for players using two amps or stereo rigs with a wet/dry approach.
I’d be happy if this kind of flexibility could be considered for a future firmware update.
Thanks again for your support and for continuing to develop this incredible unit!
