Home Forums Products Stompboxes H90 Bluetooth does not work on Mac Monterey Reply To: H90 Bluetooth does not work on Mac Monterey
#190693
    You’ll need to “forget” the H90 from the Mac bluetooth settings, and also go into the Bluetooth settings on the H90 and select “forget”. After that, try the pairing instructions again from the start.
    If you had it working before and you have not changed any settings or updated your computer’s OS version, you should be able to connect again without updating your OS.
