Home › Forums › Products › Stompboxes › Harmonized Lead with two Guitars (80’s Metal Style) › Reply To: Harmonized Lead with two Guitars (80’s Metal Style)
June 28, 2025 at 1:14 pm
#190753
… Band Mix with HotKnob …
A victim of the disappearing bracketed B trick. To clarify:
- Diatonic Pitch Mix, mapped to the HotKnob (A).
- Sculpt Band Mix, mapped to to the (B) HotKnob
- Next, map each HotKnob in turn – (A) and (B) – to the (P) HotKnob.
That will give you easy access to versatile mixing between guitar voices, distortion multi-bands, or both simultaneously. Balance point for all voices & HotKnobs is at the midpoint (50).
Although it’s intended for single note lines, this Program is very forgiving of power chords, and many double-stop note combinations.
