Home › Forums › Products › Stompboxes › Routing on H90 in different modes › Reply To: Routing on H90 in different modes
August 7, 2025 at 1:50 pm
#191433
Maybe my article’s order confuses you, sorry about that.
Here is the first scenario:
- If I’m using I/O 1&3 on H90 to send&return 1&2 on QC. H90’s signal should be in mono
- Insert mode: disable insert 1, using only the main signal chain on H90 should work as a single FX loop block in QC. But what’s going to happen if I use insert 1 as another FX loop in QC? Insert works as part of the signal chain in H90, I can’t figure out what will happen if I using it as FX block in QC.
- Dual mode: I get path 1&2 in mono, easy to understand. In QC I can use 2 FX loop blocks representing path 1&2 and put them anywhere in the signal chain.
Here are the second:
- If I’m using I/O 1&2 on H90 to send&return 1&2 on QC. H90’s signal should be in stereo
- Insert mode: same as using I/O 1&3 except the main signal chain becomes stereo without any insert.
- Dual mode: only path 1 is available but it’s in stereo, which makes no difference to insert mode above.
To make it short, I’m wondering:
If I use I/O 1&2 on H90 and put it in QC’s FX loop using insert mode (QC do support stereo FX loop), does it work? If it does, is it a stereo signal chain ? Which makes it work just like in dual mode with only path 1.
I know it’s not a usual way to use it, but I’m just curious about it.
