Home › Forums › Products › Stompboxes › H90 dub style delay using send level › Reply To: H90 dub style delay using send level
August 9, 2025 at 3:02 am
#191448
Thanks a lot for the idea brock!
Yeah I agree a quick knob is awkward! My original idea was to just want to prove it works first. Then- after it’s working with a quick knob – I could get an expression pedal to control it or similar. I have an ‘elektron analogue heat + fx’ effects unit and that does allows you to run the delay effect either ‘wet dry’ style or ‘send’ style so was hoping the h90 would have similar facility.
But- I’ll try your perform switch solution and report back! (By way, the use case here is for vinyl DJing – I have the h90 connected to the send and return on my dj mixer. )
