Home Forums Products Plug-Ins Ultra Channel not showing up in ILok Reply To: Ultra Channel not showing up in ILok
#191715
highmtn
    I have LUNA and also Ultrachannel.
    It can be confusing.  If I remember correctly, after going to the Eventide site and downloading the Ultrachannel software, you then start up LUNA.  in LUNA you go to the “New Plugins” area and let it scan the new plugin.
    THEN open a project in Luna and select a channel to run Ultrachannel.  At that time, I believe you will get a dialog to authorize the new plugin.  It will do the iLOK portion of the authorization at that time.  Just keep clicking through the questions, and it goes online to make sure that Eventide is telling iLOK to let you run the plugin.  You see a couple of online authorizations take place, and then you’re good to go. Until you do that, you won’t see Ultrachannel in your iLOK account.
    Also, I believe you have an authorization code that comes from following the instructions you get in the email from Eventide. That email has a link to the download software area and also an Authroization code area. You may have to have a window open to copy/paste the code from that locations when you are opening the plugin for the first time in LUNA.
    It’s kind of a convoluted path, but if you keep track of the links to Eventide and get the plugin into your computer with the Eventide Authorization code, that will enable the iLOK portion of the mystery sequence.
    Bob
