Home › Forums › Products › Stompboxes › H90 Looper › Reply To: H90 Looper
August 27, 2025 at 2:56 pm
#191743
You can have a looper loaded in Preset A and use a different effect for Preset B. This way you can play along with your loop while also using another effect.
If you load a different Program, then your loop will fade out depending on your spillover setting.
