Home Forums Products Stompboxes H90 Control – Create user preset Reply To: H90 Control – Create user preset
#191815
Sorbz62
    Select a blank program from a user bank (top left), you’ll see 2 blank presets.  Click on A (above the parameter box),  click on ‘presets’ (bottom right), select an effect type (eg delay) then the algorithm (eg  Digital Delay), then choose a preset from the list on the left.
    OK so far?
    Select B (where it says B above) and do the same for that one.
    Adjust all the parameters to your liking.
    Rename the prog and press ‘save’ (top right)
    Simples.
