Home › Forums › Products › Stompboxes › Mono in stereo out pedal in H90 Loop › Reply To: Mono in stereo out pedal in H90 Loop
Hi Brock, thanks for your reply
Export Import from Insert to the Dual Mode now works fine!
I have one last doubt : I’m in Dual Mode routing because I want to use the H90 in my amp FX loop and I read that it is recommended in my four cable method.
Well, in the Routing menu I can choose different alternatives such as Path 1 Series, Path 1 Parallel, Pre/Post, Path 2 Parallel and Path 2 Series
my question is: since I’m in Dual Mode, why doesn’t it automatically set to Pre/Post? I see that under the Routing menu it starts with the “Path 1 Series” for every preset and I have to change it to Pre/Post manually
So, the answer is that I should save this routing setting for each preset?
Let me know. Thanks
