Home Forums Products Stompboxes H90: Gradual changes via hot switches? Reply To: H90: Gradual changes via hot switches?
#191857
cestlamort
    Thanks for the confirmation.
    As I understand it, the hotknob cannot be controlled by a switch in this way, correct? e.g., map the parameter(s) to be changed to the hot knob, map the hot knob to a hot switch for a gradual change.
    Footnote: It should be possible, however, to assign a midi cc to the parameter(s) and/or hotknob and then use a series of cc values to do the gradual change, such as with Morningstar’s midi waveforms. Unfortunately, I no longer have a Morningstar MIDI controller.
