Home › Forums › Products › Stompboxes › Expression pedal as volume pedal? › Reply To: Expression pedal as volume pedal?
September 12, 2025 at 9:47 am
#191986
Ive successfully assigned my expression pedal to output gain. However, when I assign a “start” and “end” value, the pedal still has a range of -60dB to +12dB.
Are you mapping your expression pedal at the Global level? There’s an alternative solution described in this post. Just substitute ‘expression pedal’ in place of the Aux switch, and set the range appropriately. -60 to 0 db, or similar.
