Home Forums Products Stompboxes H90 calibration seems off Reply To: H90 calibration seems off
#192228
    1. Is your H90 updated to the latest software version?
    2. Are you mapping the “Manual Shift” parameter to the expression pedal? It doesn’t look like it since I can see that parameter is not updating on the screen when you move the pedal. You need to map the Manual Shift parameter to achieve smooth pitch sweeps.
    Let me know if that helps.
