Home › Forums › Products › Stompboxes › Pre/Post routing on H90 with pedalboard signal chain › Reply To: Pre/Post routing on H90 with pedalboard signal chain
October 17, 2025 at 9:29 am
#192653
Yes, you will have the correct mono/stereo behavior without any further configuration if you connect to Input/Output 1 for the first path, and Inputs/Outputs 3-4 for the 2nd path.
