Home › Forums › Products › Stompboxes › H90 Looper – simultaneous record › Reply To: H90 Looper – simultaneous record
November 17, 2025 at 8:59 am
#193329
Hi Is it possible to trigger two loopers to record at the same time via MIDI? Once recorded (in parallel routing) I could adjust the lengths to go out of sync with each other, or mess around with speeds, but based on the same loop input. Might be easier for me than trying to record two inputs the same but separately! Thank you .
Here’s my approach: … Two Looper Algos At Once. You can easily substitute three MIDI CCs [127=ON values] for the Aux switch mappings described there. The key is to map the same ‘trigger’ to pair up REC, PLAY, STOP Performance controls in both instances.
