Home Forums Products Stompboxes H90 “B” controls not working? Reply To: H90 “B” controls not working?
#193332
    How are you connecting your guitar/instrument to the H90? Are you using a mono input/output, stereo input/output, or something else?
    When you are using an algorithm with an A and B voice, then the A voice will be panned to the left output, and the B voice will be panned to the right output.
    You also need to make sure the Pitch Mix or Delay Mix parameter is at a value where you will hear both voices.
    A simple example to test would be to load the Digital Delay algorithm and the default preset will have 2 delays at a 1/4 rhythm. Change one of the delay times you should hear both voices.
