Home › Forums › Products › Stompboxes › H90: connecting multiple inputs (one stere plus one mono) › Reply To: H90: connecting multiple inputs (one stere plus one mono)
#193371
Baldadi
    Hi there, reviving this question I guess 😉
    So, I tried this. I have 2 synths: 1 stereo, 1 mono out. Even thinking of connecting a 3rd mono synth to input 4…
    Want them all to be processed through the H90, like a mixer would: so whether or not any program is active, all inputs are ‘processed’ with the 50% mix level.
    Also watched the ROUTING video…
    Is it correct that the above solution seems to only work when the Program is ENGAGED and that stereo1/2 is the only signal coming through when NOT engaged?
    Is there a way to process the signals of ALL synths, even when the program is not active?
    Or should I use some trick like create a new program with 2 presets @0%wet…?
    Not very elegant, maybe you can help me with another solution without me having to spend some more cash on an additional mixer like the Radial Key Largo?
    Maybe I am just missing something otherwise I’llm put a feature request for this I guess 😉
    Kind regards… RB
