Home › Forums › Products › Stompboxes › Line vs instrument H90 › Reply To: Line vs instrument H90
One of the things i love most about the H90 that i didn’t even consider before i got one is putting my “amp” (UAFX Dream 65) in the middle of the signal chain (insert). This way i choose on a program by program basis where’s the best place for each algorithm to sit. If i want to use a wah or fuzz i can put it in front of the amp. If i want to use it more like studio effects, like the Black Hole reverb, or the synth like stuff, they can go after the amp. And some algorithms i sometimes put before, and sometimes after, like the pitch stuff; but with the joy of rerouting by turning a knob it means it’s usually obvious by listening which order you want. I think this is only possible using the instrument level, because it plays nicely with the other pedals that way (on my board it’s not the first or last thing in my chain). I have no experience of the Two Notes Opus, but i assume it is also instrument level to work with other pedals, unless using the XLR outputs, which is more likely to be line level.
