Home › Forums › Products › Plug-Ins › Octavox: Triggering Snapshot changes with midi controller › Reply To: Octavox: Triggering Snapshot changes with midi controller
#193444
    Mapping the Snapshot selection to a MIDI CC is not the best way to accomplish this.
    Since you are using Ableton Live, I would suggest using MIDI to trigger the different snapshots as this is a more precise way to adjust the snapshots. You can then use the Quneo to trigger the MIDI clips in Ableton.
    In my screenshots below, it shows how 1 MIDI clips is mapped to the Global 1 snapshot, and another clip is mapped to Global 4.
    More info about MIDI clip automation in Ableton can be found here: https://www.ableton.com/en/manual/automation-and-editing-envelopes/
