Home › Forums › Products › Stompboxes › A question about using H90. › Reply To: A question about using H90.
#193491
myoungsoo jung
    1. The device I’m using is music’s efx6, and h90 is connected to a parallel mixer and controlled as a midi.
    For example, if you set all the h90  1presets together on 1st to 5th in the switch and change the switch presets, the h90  1presets will be re-loaded every channel change, causing a disconnection in the middle. Can you remove the re-loading part when you bring back the same presets?
    *I’m also attaching a picture of the pedal board I’m using.
